I recently towed my boat about 1000 miles for vacation, and it is having some weird tire wear and I can't figure out why....
The tires are wearing like they are seriously under inflated: both tires, on both inner and outer sides, are very worn, yet the center 3 or 4 inches of tread look brand new with almost no wear. They have actually worn on the inner and outer edges to the point that there is NO TREAD LEFT AT ALL! This was all worn away over the 1000 mile trip. I check tire pressures very frequently, and they are both set exactly as they say on the trailer AND tire at 50 psi each cold (and I use a digital gauge, checked with a mechanical gauge for accuracy). My tires are each rated for 1850 lbs, and my boat and trailer only total about 2700 lbs. Trailer is leaf spring with solid axle. And just a side note: I never, EVER, tow over 60 mph, period.
Any idea why they would wear like this?
