Please help, I think I damaged the fuel pump
Andy1984
Hi everyone,
My Motor Specs:
S#: 0T085371
M#:25EL 4STR
It is a 2000 Mercury 25hp bigfoot
Yesterday morning, I forgot to open the valve on the gas tank. After 25 minutes of driving, The engine stop. I immediately opened the valve, but i think it is too late. Because the engine would run for about 2 minutes then stop again. I have to manually pump the primer in order to get the engine runs. Did I just damaged the fuel pump? I disassembled the fuel pump, and the only thing that doesn't look right is the diaphram. What is else could be wrong? Here is a picture of my fuel pump. Thanks
Also,
can someone please help me find the fuel pump kits for my motor?
Wingedwheel
Re: Please help, I think I damaged the fuel pump
If the diaphram doesn't look right, replace it. You can get a fuel pump kit with all your gaskets and a diaphram very reasonably.
Mi duckdown
Since you have opened the fuel pump already, might as well get a rebuild kit.
A Good, merc dealer should have one on the shelf.
Andy1984
Thanks everyone, I am going to try the rebuild kit and test it again.
