This is my first post. Bought a used boat and it came with a 1977 Merc 700 Series Thunderbolt 70 Hp.
I've read in other posts that the warm-up lever should not move when the throttle lever is out of neutral and the throttle lever should not move when the warm-up lever is engaged.
What could be wrong if that is the case?
Also the warm-up lever works fine when starting the motor. I am able to place the warm-up lever all the way down and the motor idles fine.
As soon as I push the throttle lever forward, the motor wants to conk out. Most times it does...other times, I go extremely slow on the water, even with the throttle all the way forward.
If the motor does die, I can only get it to go forward using the throttle and warm-up lever together.
I've replaced the power-pack with a new one because it was only firing on one cylinder and that was the issue with that.
Any ideas for this newbie? Thanks in advance.
