Re: Maybe the dumbest Question ever asked...
These are called surface gap plugs and are used on electronic ignitions. They require the very high voltage delivered by electronic ignition to fire and usually will not spark with magneto ignition or points and coil battery ignition, especially at cranking speeds. They do tend to foul easier and if you start having problems with starting or idle, remove and clean the plugs before trying anything else.
Since the center electrode is completely surrounded by the plug shell, they are not exposed to combustion heat and are cooled by the shell itself. Because of this, the plugs are "dead" cold. This type plug is used in some outboards to prevent pre-ignition and detonation. Do NOT use a regular bent electrode plug in your engine.
