Ive been troubleshooting my motor 1989 johnson 140 looper for a while now. Pulled all the carbs and cleaned them thoroughly with carb cleaner and compressed air. Replaced spaghetti gaskets and side gaskets on all 4. Noticed when I was installing the last carb (lowest left) that it wasnt seating flush against the throat no matter how good I tightened the 4 bolts. It appears as if that carb is warped. Has anyone had this problem and do I have to buy a new carb or can I use gasket maker and just seal it up real good?
