new ring gear on fly wheel......... AGAIN
fishingman220
SO, today i chewed all the teeth off the flywheel again, for the 3rd time. I have a 96 5.7 mercruiser. I will be pulling the motor and putting a new gear on it and maybe a new starter bendix, while its out i will be aligning the starter and check the need for shims, and anybody think of anything else i can do to prevent this from happening again? maybe a new starter??? i donno, i had to be towed for the first time today and i was so mad i was ready to pull the plug and call the insurance company(jk)
Bt Doctur
Re: new ring gear on fly wheel......... AGAIN
might check the number of teeth on the bendix .should be 11
Alpheus
Is it not engaging when this happens, or is it happening while the engine is turning over?
I have seen a few chewed up flywheels from "kickback" on a motor with timing issues...
fishingman220
i will check both, thanks for the ideas
