I have a 1995 25 hp mlht yamama outboard with automatic oil injection.
the motor seized last year so i pulled it apart and found that a bearing seperator in the center of the crank came loose and tore it self up. Has anyone ever seen this happen??? A steel roll pin holds this seal in place and it bent and came out of its cradel?? this maybe was on lack of oil problem but not sure?? it did not distroy the aluminum block only itself????( very strange)
ANYWAY.......
My main reason for this post is to ask a question in reference to eliminating the oil injection all togeather?
The crankshaft oil pump drive gear is shot and very expensive to replace so a mechanic told me to just eliminate the oil injection system all togeather and mix the oil and gas in the tank. Does any one see this as a problem ??? i have received mixed answers and opinions to this questions.. any help would be greatly appreciated!
ANYWAY.......
