I have a 1995 Searayder with a 120hp mercury sportjet. It only has about 145 hours on it. I cant get it above 3000rpm. The bottom 2 spark plugs are wet. I have replaced the plugs, swapped out the plug wires and replaced the bottom two coils. They spark, but maybe not enough? Early on I removed the carbs and went through. All jets seemed clean as a whistle. Do I have a switch box problem or stator? <br />Thanks.
