Can your thermostat be damaged if not removed for winter storage?
What about if you had your outdrive UP all winter, can it damage the impeller or gaskets and force it to work at 75% only?
I just flushed my system, pull the plugs on the block, manifolds and raisers that's it.
Block is fine but log style manifolds are running at 210 degrees under muffs.
