puddlesplasher
- Mar 19, 2009
- 47
Hi all,
I hope the heading is self explanatory but just in case it's not I offer this question.
The O/B is a Johnson 30hp electric start by turning the key. What I need to know is how to start the O/B manually by rope, just in case anything happens to the twin batteries. Hopefully nothing will ever happen but I believe it is best to be prepared for all eventualities.
The mechanic showed me upon my questioning a little black knob, arrow shaped, right side, bottom of the engine when the O/B is transom mounted. He said that it should be in-line for normal use but to to turn it at 90 degrees to its normal position when manually starting.
Nothing else was mentioned so I presume there must be another steps to follow.
Which way does the rope wind on? What diameter of rope for the flywheel? How many wraps/turns around the flywheel. Is it easy to pull? Is there anything else I need to do?
Many thanks in advance if anyone is able to assist me.
Puddle.
Puddle.
