109jb
- Jul 15, 2008
- 1,590
Well I finally got around to buffing out my Sea Ray. The previous owner had painted part of the green trim with cheapo silver rattle can spray paint to hide a small area of damage. I started by removing the paint with acetone and then buffed. The gel coat was oxidized as you would expect. I did try the Vaseline trick that so many swear by. It did give the area a shine, but not to my personal satisfaction. Unfortunately I didn't take a picture of that experiment. I then took out the buffer and wool pad and proceeded to buff the gel coat using Meguiar's oxidation remover. the before and after are shown below. The shhine that came up is much better IMO than what the vaseline did. Including removing the bow rails and cleats, buffing the entire boat, and re-installing the cleats and rails, I invested about 6 or 7 hours hours into buffing the whole boat. It isn't perfect and there are dings and a few spots that could use some wet sanding with 1000 grit and buffing again but it is a whole lot better than it was before. Certainly very respectable for a 22 year old boat. The boat is in the barn and I can't get a good picture of the whole boat right now but I will update when I can.
