Re: 25 hp mercury outboard
I had to rebuild my carb on 25HP mercury outboard, When i was done had the same problem. Engine would run for a bit then quit. When the engine was about to stall out i could pump the bulb and it would run fine. So i figured the gas was not being replaced in the carb bowl. This is what i found; I rebuilt the carb in the garage. My kit came with a couple different mounting gaskets so i chose the gasket that looked closest to the original, matched it up to the carb and it looked great, however on the motor one of the ports was offset from the port on the carb. looking at the old gasket the hole for this was elongated, the new gasket the hole was not so it covered up the hole on the engine. I elongated the hole on the gasket, and it worked fine. Good luck!!
