I have run the specified sensor coil resistance test and I'm getting a reading of 34 ohms on all connections. One manual I have says I should be getting at least 40 + 10 ohms while another chart I located says 45 + / - 10. I'm not sure what one to believe and if I use the + - factor I'm 1 ohm short.
I'm experiencing popping and cannot get a steady DVA reading on the power packs. Is this in any way related and is my reading too low in either case?
