Trim problem
affa
Hi
My trim motor doesn`t run when I push the button up or down, it only clicks in the solenoids.
I believe it`s a Oildyne pump - on a 1986 mercruiser alpha one drive
Is the motor stuck? Or can it be some electric problem?
Regards
Affa
JustJason
Re: Trim problem
You've verified that your solenoids are clicking, have you checked to see if you have 12V on the hot side of the solenoid (main terminal) and then checked to see if your getting 12V out when activated?
