thanx for viewing. 75 hp force which is attached to a 1996 17ft nitro. Boat came stock with trim gauge. Gauge not working. Tested gauge,gauge ok. Found lead to sending unit dark brown wire/ white stripe disconnected at harness. Checkd for continuity from wire to gauge. continuity good. here is the question does anyone know where this wire is suppose to connect am I missing something. I ve searched and found nothing that this would plug into. Is there a part number for a sending unit?pls help thanx fro your replys.
