Hi Needs some Help, Just bought a 40 hp Merc and 13 ft Whaler. Motor did not run, My Mechanic put in fresh gas ran good did not pump water.Removed lower until and installed new water pump kit. Started motor pumped water just fine. I started motor the next day no water.Mechanic then dropped lower unit impeller was destroyed. Then removed thermostat ran without it installed ANOTHER new impeller. Before this ran compressed air through motor let some vinegar sit in block for a few hours. Put all back together AGAIN Started motor ran real good pumped water great. Mechanic left and I put a barrel under motor started up and did not pump water again it did exactly the same thing again. pumping on the first start then no more water. I assume when the lower unit is dropped I will have a destroyed impeller?? Can anyone help me I do not want to put anymore money in this. I have not called my mechanic yet. I was hoping to get some feed back her Thank you for any assistance you can provide.
