john bland
- May 26, 2010
- 6
I am new to boating and am having problems keeping my boat on the water. Once the motor is primed and running it stalls out. I believe it could be the fuel pump does not work, as I can again prime it and it will start,run then stall again.1.)Is there a sure way of checking to see if it is the fuel pump If it is the fuel pump: 2.) is it hard to get to and change? 3.)my motor is a 1971 60 hp evinrude and seloc does not have the manual in stock so I will have to read the on-line version has anyone used this service :is it easy to understand? Or should I just send it to a repair shop? I am not wealthy so money could be a problem!
