I purchased a 4hp tohatsu outboard from an online dealer.
filled the onboard tank with fuel and engine started and ran as expected.
Closed fuel valve engine sat a few weeks. Next attempt engine would not start.
Question 1. The level of fuel in the onboard tank was just below the fuel pump and the engine would not start until I added fuel until it was above the fuel pump. Is this normal??
Question 2. Engine now runs rough and occasionally stalls at low rpms. It seems to have happened when I starting using an external tank. Contacted a local dealer and they said if they have to clean carb it is not covered under warranty. Is this correct? Even if there was something in the fuel the filter should trap it . tried fresh fuel and changed plug. I just wanted to know if anyone had similar issues before i bring it in.
