I'm wondering a few things about this latest turd I acquired. I believe its birthday is 1979, but not sure. I found out that the stock engine (160 hp merc L6) has internal freeze damage, so I have to find a good block to work with. My main question is about the hull itself. The bottom part is white, and the cap is a very faded ugly light green. Is it possible to actually paint the cap and have it last without some sort of adverse effect? I was thinking of some shade of blue would be nice to go with the white bottom. The Bottom part of the hull has several cracks in the gellcoat. Some are long, up to 6+" and there are a few chips and blisters as well. These cracks have a name (I think) but its escaping me now. Is crazing it?? I don't remember... If I get nuts enough to try and repair this, whats the best way? Lots of sanding I presume and maybe some type of filler? Then is it possible to paint the rest of the hull white again? I was wondering how paint holds up to the pounding of water. Any thoughts? Also, on these older boats, the serial number is a lot shorter than what I'm used to, so how to you obtain any info about it? It's a Wellcraft, Model W1850V, and the serial # is 29292. I'm guessing that means its 18.5' long, but that's all I can figure out.
