pine island fred
- Dec 20, 2002
- 1,144
YAMAHA 40 hp. 2 stroke. C40PLRS, believed to be a 94. Abandoned attempt to replace the motor mounts and am putting the thing back together. Person before me started to pull the powerhead and walked away from it. Determined its going to live its saltwater life out with what mounts are left and am reassembling it as best I can.
The shift and throttle levers are external. Under the cowl I found a thin cable that is attached to the throttle linkage, is about 8 ins. long and can only go in a mounting hole that is in the guard that houses the rope for starting ( also has an electric starter ) . Although it is connected to the throttle linkage, it appears to be controlled by the shift linkage. Anyone have any idea what it does. Cable has like a small hook on it. Could it be for rope starting interlocking ?
I hate putting other peoples stuff back together. Not surprising a lot of mechs. will not touch something this old. thanks FRED
