Newbie here. Hello all......This last friday night i hit something under the water and mangled my prop and skeg. After that the engine would run fine in neutral but kept stalling out in gear. Trolled back to the dock. Got it home, took off the prop and put the muffs on. Prop shaft runs straight as can be in forward. Motor seems to shake more than i remember though, even in neutral at idle, its a evinrude 1982 50hp 2 stroke. is it possible i could of threw out the timing by hitting something? I have a new prop on the way. Any help is greatly appreciated. Thanks
