I have a 1994 60 Hp Mercury on an 18'sun tracker (Bass Buggy) pontoon & at times you can be running down the lake at full throttle & with just small chop the motor will rev up for a second & then catch again. I have had the prop hub checked & it is ok.
The trim tab is missing from this motor & I am wondering if the open cavity could be causing this. I have also been told that a Hydra-foil might help solve this.
The motor is set as low on the transom as it can go. I have considered adding a 6" manual jack plate to experiment with lowering the motor.
any help would be greatly appreciated.
