I have a 1978 85hp Evinrude outboard that i am having problems with. This is what it is doing: It starts hard, and doesn't run at full power. When i take the plugs out, one plug is wet and the other three are dry. I have checked spark and have spark on all plugs. I have taken the carbs apart and cleaned them. The first time after i took the carbs apart and cleaned them and cleaned the wet plug then took the boat out i had lots more power for a minute or two and then the motor just bogged down again and the power never came back. Any ideas and also what would cause just one plug to be wet?
