kevin_in_utah
- Jul 27, 2010
- 1
I have a 1966 Evinrude Big Twin 40. this is the first boat i have owned. I bought it last year the boat is a 1958 alumacraft flying D. i found some on here that look just like it. and the motor is a 1966 Evinrude big twin 40. any way last year it ran fine other then it didnt seem to have much power and it used a lot of gas. this year i got out the boat and started the motor up and it ran fine. i cleaned up the spark plugs and it ran a little better. i took it out fishing . and when i got it in the water. it started up and ran for a second then died. it has a pump bulb on the gas line that when it is working i can pump the gas up to the carb then when it is primed the extra gas will come out the front of the carb like a over flow. now what seems to be happening is the gas bulb is pressuring up and no gas is coming out of the over flow. i have pulled off the gas line befor the filter and after the filter and i can pump gas threw just fine. then i pulled the line off the carb and can get gas to that point. i have pulled and drained the fuel from the drain at the bottom of the bowl on the carb. then i can pump the gas again. then it pressurizes agin and will not come out threw the over flow. does anyone have any info about this problem? i am thinking it is some kind of a float problem.. but the gas should still come out of the over flow . right? so any held would be greatly appreciated.
thank you
thank you
