Re: wanna convert jet boat to outboard
its a inboard jet drive mercury sport jet 90hp. and its not ll that much haul reconstruction just fiber glassing the hole where the jet drive was and installing a jack plate and a new outboard with controls. the boat weigh just over 1000 pounds and will hold 6 people or 900 + people and gear. it does not have a max horsepower rate but im thinking a mercury 90 horse outboard would work might be kinda big sense the jet drive only puts out around 65 hp.
Aha, I completely missed that you'd written "sport jet"! Sorry, disregard my lengthy post.
In my opinion, you're not only dealing with a HP issue, you're also dealing with needing to figure out if the hull will actually handle the major change in the powerplant. For the actual work on the hull to do what you want to do, you might post to the Boat Topics forum; I think I've seen discussions on I/O-Outboard conversions there. You might get some good practical advice.
Just off hand, the factors I might see coming into play are that the weight support of the engine and angle/torque of the thrust forces are quite a bit different with a floor mounted sport jet shooting straight out the back vs. a transom/jack plate mounted outboard whose thrust torques the engine and the bracket.
There might also be different support needed back there for trailering as w/ an i/o type of setup, all the weight just rests there, while an outboard as you might imagine, again kind of hangs off the back and can torque the transom as it bounces along. It might actually require some reinforcement of the rear of the boat.
It will probably require some change in your trailer set up because the outboard will definitely change the balance and therefore the tongue weight, and might affect handling if it's too light on the tongue.
But I hope it works out as easy as you hope...Good luck with your project. I'd be curious to see how it works out.
