This is related to my "Throttle swap" question. 1985 Bayliner Capri bowrider W/ 85hp Force O/B. What should the max RPM range be for this set up? I'm alone in the boat & at WOT I'm hitting 4900 maybe 5000 RPM. Should this be higher? It sounds like the motor has more in it. I asked another question re: throttle swap, because when I bought the boat the guy said the only issue it really had was the throttle was "upside down", I don't know what caused this, he never said but the day I picked the boat up the mech. had repaired/jimmied the throttle to operate normally I'm thinking the seller asked the mech. to try to fix it real quick so I didn't back out of the deal because I was asking about the throttle.. Like I said, it sounds like the motor has more in it. Should I be more in the 5500 range with this boat & motor? I was just going to replace the throttle all together. What do you think??
