Boy, it's sure amazing how a $10 ignition switching going out can have such a ripple effect. I posted a while back about the switch going out which I thought resulted in a damaged starter. Looks like a damaged flywheel gear is still causing us "noise" while starting. I examined it and found just a couple teeth that have enough wear on them to be causing the noise. Ugh! So, I'm looking at replacing the gear, but not looking forward to it mainly because of frustration that it was all caused by a simple part failing.
So, what am I looking at? Probably my biggest question is "What's the best way to lift the engine out if you don't have any over-head pulley system?" Tips or advice on the repair?
