Hello,
I'm new to Outboards but I'm mechanically inclined.
I've just been given a 15'6" Hourston Glass Craft with a 1978 70 HP Merc Thunderbolt on it. Its been parked outdoors for 5+yrs and I started it for the first time today with ears on, It ran quite well considering. I ran Sea Foam in the first tank of gas and let it run for about 20 Min. I noticed that when I would bring the RPMs up to about 3000 my Gage would drop off to 1000 and it would start to stumble a bit. Water flows very well out the cooling tube. It will stall intermitantly at idle.
Is this normal ?
Any suggestions of things I should be looking at before I go out for my first run? The hull is in very good shape but I'm concerned about the engine.
Thank you for any suggestions and help you may have!
Is this normal ?
