Re: Bilge pump
Hello Stok..
You want your pump in the lowest part of the bilge "when in water" and that can be accessable..
How you would mount it would be depending on the pump itself. Some have different mount points.. you would most likely have to mount it to the glass bottom .. or if yours is alum you will have to make a bracket.
Then of cource there is your auto-float switch .. which is mounted accordingly..and direcly connected to your battery ( with fuse ).
Do you want a dedicated switch to turn it on when you desire as well as auto ? ..then you have to run seperate wires and switch to your switch location/battery (with fuse)/pump.
I believe your pump instructions show you diagrams of every way you want to hook it up.
YD.
