I get her running yesterday on the earmuffs. Sounded great idled perfect and no backfiring. SO I tried the cylinder drop test and took off the wire from each cylinder while idling. When I pulled cylinder 1 and 2 the motor killed but cylinder 3 and 4 made no difference. Anyways took it on the water and left the boat on the trailer. Got her to idle barely and then I put it in gear to load test and she killed. It did seem to run at 1/4 throttle but anymore than that and killed everytime. Everyone is telling me to rebuild the carbs which I know I need to do because the gaskets are worn, but now I think it could be ignition. But why does the motor purr like a kitten on earnuffs but soon as it hits the water it barely will start??
