mariner 60hp wont start
beatsworkin
hi all i have a mariner 60hp 3cyl 2 stroke premix serial n.o A111169 i replaced trigger on it last year ran fine used it a few times this year it ran fine but while out the other day i stopped to fish and it failed to start i checked and im gettin no spark to any of the plugs i cleaned all connections still no spark i disconnected the black/yellow wire from switch box still no spark so that rules out kill/key switch i think ? also disconected the 2 yellow stator wires from the rectifier still no spark i bought a multi meter tested all wires with no faults when i ground the blue/stator wire which is connected to switch box i get readin of 500ohms when i do same with the red stator wire connected to switch box i get readin of 1300ohms meter bein set at 2k as at 200k i get zero readings this is without crankin engine now if i take these wires of the switch box i get no readings when i ground them am i doin this right and are these readings correct ???? any1 got any ideas what to try next???????
