Do johnson 15 spline omc props work on 85hp merc's from the 80's?
andrewbabich
I've got a bunch of johnson props and I need to put a new one on my buddies older Merc engine.
Also what would an ideal prop size be for this 17ft trihull with a 85HP merc be for wakeboarding and general cruising.
Chris1956
Re: Do johnson 15 spline omc props work on 85hp merc's from the 80's?
I adapted my Merc V6 prop to fit my Johnny 150HPV6 motor. I needed to drill out some of the splines depth, and adapt a Merc thrust washer to fit the Johnny propshaft taper.
The Johnson props would need to have a 4-1/4" hub diameter, and have the same spline count as the Merc propshaft.
I would think a 15-17" pitch prop would be correct for that boat/motor combo.
iBoats does have a Prop forum, that you could consult.
