81 Checkmate
- Jul 20, 2010
- 1,360
1981 18ft bow rider Checkmate V-8 305 190 Hp, 4 barrel carb. After finding the lifter would not lift pushrod. Took motor apart found out lobe total ground off cam. This was #6 Cylinder Ex Valve. This is Bull crap i think we should see if it is coverd on warrenty by GM. I wish it still was 1981. HA HA. Everything else looked good. Copmpresion test 130psi on 6 cylinders # 1,2,3,4,7,8 150psi on #5 cyinder and 115 on #6 cylinder. Ok not so good but good we found the problem. Need new cam and lifters. My Question is should we beef up alittle or just stick with stock. does any one have any input on duration and lift we should go with. P.S. i know it just a puky 305 but it is what we have and dont have money to buy a new motor.
