I would like to find the most efficient prop in terms of offering the least amount of prop slip. I am interested in attaining the fastest cruising speed available if I don't already have it.
Current prop is Yamaha aluminum 9.25 x 9 pitch 3 blade
2008 Yamaha 9.9hp short shaft 2 stroke 2.08 gear ratio (I completed initial break-in 1 month ago) 4500-5500 rpm
2009 Aquamax 9.5' inflatable catamaran
Boat weights 100lbs + 3 gal fuel + 81lb outboard + 2 people together weighing 230 lbs (100f+130m)
WOT 5400 16mph
note: with just me in it 18mph sans the 100lb female
note: borrowed a Yam 9.25x12 3 blade AL WOT 3800 15mph
I want to try both the Turning Point Rascal AL 9x9 and their 9x10 3 blade
Plenty of other possibilities are available as well from SS, going up to 4 Blades, composites, as well as Yamaha's "Duel Thrust" plastic and aluminum options that I vaguely understand modulate the exhaust venting for less initial slip designed for bigboats/ sailboats.
Thank you just trying to learn something
WOT 5400 16mph
