Re: Stuck stringer in down position
remove the quadrant gear. 9/16" wrench - 3 bolts
a hard slam often breaks the 2 roll pins through the horizontal shaft- the broken off pieces of roll pin can jam things up... gotta disassemble the clutch hsg. to clear it.
the shaft is only $10 or so
