dozerII
- Oct 25, 2009
- 6,527
We finally got the boat out yesterday for the maiden voayage. The outdrive had a whaletail and turnbuckle adjustable trimtabs on it when I bought it. As soon as I brought it home I turfed the whale tale and made sure the trim tabs were set even and they were set down to about 3/4 inch below the hull.
Specs. 72 Starcraft 18' openbow approx 1800lb, Mercruiser 120 1.98 GR, Mercury prop 15 1/4 X 21 GPS speed 33.9 mph at 3900 RPM
The prop on it is in real bad shape bent and chewed up. When we first hit the water I could not get the bow to come up, the trim tabs were so effective at 20 mph the prop would blow out and I would have to back off. I adjusted the trim tabs twice till they are almost parallel with the hull and things got way better, but it takes very little up trim for the prop to ventalate and blowout.
What recomendations do you have for this problem and props. I ordered a Solas 15,3/10 X 21 from I boats but it will not fit and I am trying to return it. Would a Hustler 14,1/4 X 21 or 23 work?
Any help would be appreciated.
Thanks Glen
Thanks Glen
