That was a teaser, I know that it is needed, but while you are here, please keep reading?
I have been working with the timing on the 1988 GT200, the first time out I had a 4 blade 26 pitch prop, set the motor at 18 BTDC per the Clymer?s, then later on looking around I found a sticker that reads 16 BTDC, on top of the air box. The service manual reads as the Clymer?s. So which do I use?
I did reset the timing to 16 BTDC with a Raker 3 blade 24 pitch, the motor was not as labored as the earlier outing.
Without stopping my train of thought that I have at this moment, I am thinking that I have read somewhere that boat NOT be restricted while making these adjustments, at 4500 to 5000 rpms with a Raker 3 blade 24 pitch prop, the boat is moving around 50 to 55 MPH, I just can?t see me hanging on to the boat with one hand and the timing light in the other glancing around for timing marks.
So that brings me to my next question, do I need to have the test prop that is mentioned more than once in the manuals (Factory & Clymer?s)?
I am thinking that once I get through the WOT timing set, then move on the idle timing set, I will be at a 100% great running motor.
