donzi gt230
- Jul 19, 2010
- 92
I need to replace the water pump and the LU is stuck. The back half will flex down a bit, but it appears that the front stud is stuck to the housing. The stud itself is rusty and the housing is pitted a bit around it. I just got the boat and know it's been AT LEAST 6 years since the LU was off, but don't know when. I put a piece of wood from the cone to the trailer and lowered the trim to put some pressure on it, backed the two front nuts against a piece of metal, heated the housing and stud back & forth (letting it cool in between), tightened and loosened all fasteners, penetrating oil, mallets, sweat, bruised knuckles.....All these have been done several times back & forth for hours hoping to get it to move, but nothing. So here I am, boat almost ready, right outside the window next to me. Are there any special tricks to try? I went easy on heating the housing, should I just go for it and not worry?-I think there's nothing sensitive near that front stud, but not sure and afraid to get crazy with the torch.
Off topic: did a carb/timing synch today and those motors that I thought ran well and needed nothing are AWESOME now. Bump the key and bask in the smokey crackle!
