Ran fine for the past few months, on the river the other day was towing someone in whose motor died, engine sputtered and died.. started messing with it today, if I pump the bulb up and start it it will run for a bit and then die out.. if I pump it again before dying it will keep going for a bit.. anywhere between 15 seconds to a minute or so..
I popped off the fuel pump line running to the distribution tree, turned it over and it shoot fuel..
I tried blowing back in the inlet line to see if maybe was an air leak somewhere and it was closed, so I assume the lines are good at least to the bulb..
Bought new plugs a bit ago, so went ahead and put them in, give a few tries nothing.. I take the plugs out they look to be covered in oil, not so much gas but more so oil...
I hooked a compression tester up and got readings of 35, 35, 37, 38...
Am I reading this wrong.. is it possible for the motor to even run at that low of compression?
And what is my next step? I pulled the carbs and was planning on disassemble/clean tomorrow and giving that a try before dropping the 150 on rebuild kits...
I am the most confused at the compression readings, I used a tester once a long time ago.. screw it in, turn the motor a good few times until the needle maxes out right? Motor was cold at the time, hadn't been running in an hour or so if that has a bearing...
The only other thing I can think that might have any effect is that the spark advance got moved earlier in the day of the original issue, however I am fairly sure I got it reseated back to where it previously was.
Thanks in advance
Thanks in advance
