Hello, I am brand new to this site and it looks like there is a lot of great info! I purchased a Triton 189 last fall that has a 2003 175 Yamaha HPDI. I am not sure what service if any has been done on the engine. The dealer I purchased it from stated the engine had 96 hours on it. I have been reading the many threads in regards to O2 sensors and the VST filter. Does this engine have an O2 sensor? I realize it has the VST tank. Are these items I should check and change? If so, can this be done by a novice or should it be taken to a certified Yamaha mechanic.
I also recently changed the fuel filter on this engine. However, I can get to seal back up. When I press the primer ball hard it leaks out the top. Is there any secret/trick to get this to seal back properly? I believe it should not leak like this when priming the bulb.
Thanks!
Thanks!
