165 HP, Inline 6 Mercruiser, Rochester 2GC carburetor:
I thought I solved my warm start difficulties but seems like its happening again. Engine starts up fine when cold. Starting up when warm IMMEDIATELY after shutting of engine is no problem. Let the boat sit for a few minutes and starting is difficult. I end up removing the flame arrestor to let the carburetor air out because I have a feeling its flooded.
So, I let the enging idle up to normal op temp, shut it down, removed the flame arrestor and looked inside. Everything I could see was dry. I let it sit for a about 5 minutes, checked again and noticed the venturi cluster and the screw that holds it down was wet with fuel. Is this an indication the float bowl is leaking. I wiped the fuel off the screw then checked again after 30 minutes and the venturi cluster and screw are still wet, and looking down through the throttle body I can see a mist which I assume is vaporized fuel. It's difficult to tell, but trying to look through into the maifold, it looks wet...but can't say for sure.
The carb has been rebuilt twice since 2002. Once by your truly, and once by a company that specializes in rebuilding carburetors, and the problem of hard starting when warm has always been present.
Is it time for a new carb? Could there be a crack on the body somewhere causing it to leak and flood? Should it be completely dry in there? Or is what I'm seeing in the carb normal after shutdown? I've enclosed a pic to show what I'm seeing.
