i bought a boat 2 years ago, and every time i take it out, it dies out in the lake. it will restat, and run on 2 or 3 cylinders after it sits a while with the cowl off. i do not know if that is becasue the cowl is off, or not. i just take it off to try different things to see if i can get it to run. i have replaced the ignition coil, (it was cracked open) with no luck. it starts very hard, but i have isolated that to the electric choke not closing all the way. that was a joy to fix! i am not certain if this is electrical, or fuel related. it did something strange last time i had it running in the yard in a 55 gallon drum. it started to die, and on my way back to check, i tripped and my hand fell right on the primer bulb. the engine picked up for a few seconds. i have tried repeating this several times, but it is a hit or miss proposition. my brother said that if the fuel tank vent was plugged, the fuel pump would suck the primer bulb down and collapse it. i thought i would rebuild the pump, but the dealer said there is no kit, i would have to buy a $125.00 pump. i am really not so sure i want to do that, unless i know it will fix the problem. i installed a tachometer, thinking that if it was electrical, the tach would die if the ignition failed. when the engine dies, the tach still works. so i dont know if that is a good indicator or not. i am disabled, so paddling a 16' fibreglass boat half way across a lake is not going to happen. and working on this, is no fun either. but i certainly can NOT afford dealer shop rates either. i have tools, ex motorcycle mechanic) and i bought a " service manual" but it is a joke. it is factory evinrude, but it is only about 20 pages. not much information in it. the dealer here, has no one in the shop that was even alive in 1974, so i dont think they are going to be a lot of help, even if they wanted to be (which they DO NOT!). ARE THEIR ANY OLD (LIKE ME) RETIRED BOAT MECHANICS OUT THERE THAT REMEMBER THESE OLD BEASTS!? ENGINE MODEL# IS 85293R. it has an "electronic ignition that uses points to trigger it. i have looked at the points, they are in great shape. the engine runs good for a while, so the points are not the problem. i am not so sure about the "ignition amplifier", and the fuel system.
