Mercury Optimax 1999 225XL NEED HELP
Dwiles
I have Twin 1999 Mercury Optimax 225XL DFI 2stroke . One of them I am having trouble starting. I tested the fuel pump because it is not coming on when key is in the on position. There is 12 volts coming to the fuel pump. In the past the motor would run great on dry dock, but when you put it in the water it would only push 2500rpms then it would just choke out. Was the fuel pump failing and it finally went or do I have another problem?
sxmerc
Re: Mercury Optimax 1999 225XL NEED HELP
If there is 12 volts to the pump at initiall key up, and no pump running, then I would certainly start with the fuel pump.
