abibergall
- Jul 17, 2010
- 16
Please help I am a novice I have a Johnson model FD 10. I bought this motor with pressure tank for $75. I rebuilt the carb with a carb kit I bought. I replaced the main gasket, the float the float pin and cleaned the carb parts real good. I put it back together and I simply cant get it to run more than about 30 seconds. I set the low speed setting to 2.5 turns out and the high speed to .75 turns.
I am looking for any advice on best practice for starting the motor and to make sure there is nothing basic that I did wrong when I rebuilt the carb. Is there a way to set the float or the float pin that goes in under the float?
Sorry if these are dumb questions I really want to get this thing running.
