Hi all,
I recently took ownership of a 1967 Sea Ray 14 footer. I have to fix a small leak in the bottom (a couple of punch throughs) and am going to cut a hole in the floor just forward of the transom to make sure the stringers are in good shape back there (right above the small hole) the glass feels a little soft in an area about the size of a dinner plate.
I have looked at floor repair, and intend to glass the two holes (about the size of a dime each) from the outside, and then also patch them from the inside once I cut the hole. I figure epoxy on the outside, and then some mesh and epoxy on the inside - does this sound right?
OK, other question, it looks like the previous owner bolted the motor directly to the fiberglass transom. and this has caused a little damage (not broken through yet, but almost). I was gonna seal this up with epoxy, sand it flush, and then put a piece of aluminum on the outside to protect the transom. The transom is solid, however, there are a few cracks in the fiberglass most likely caused by bolting the motor directly to the fiberglass with no wood or anything else in between the motor and the hold down screws (wrong name probably). I have looked but can't tell forsure if there is supposed to be something between the motor and the fiberglass, looks like there was something bolted through the transom at one time, but those holes have been filled with sealer by the PO.
I am looking for advice on this - outboard on the back of a fiberglass boat, do you put a piece of ply on either side, it would have to be small as the transom is 2 inches and if I go much bigger then 1/4 on both sides I am going to have trouble getting a motor to fit. If you just tighten down on the glass it seems like this is asking for problems, but I don't know, as this is my first fiberglass boat, all my other boats have been aluminum and I always put wood on them on both sides and the motor then attached to the wood.
Thanks for looking and any advice you may have.
d
d
