I have a 12ft sea king boat and someone just gave me a 7hp sea king motor to make a matching set. I was pesimistic about a free motor but it's turning out to be a winner. Compression in the single cylinder easily hand pulled to 120psi. The previous owner said it ran but that gas was leaking from the carb the last time she ran it. We hooked up hoses and pumped to prime. Turns out the leaks all seem to be from bad fuel line under the cover. So why am I starting a thread?
I need to know more about the motor. I need to know:
1. year
2. ratio for oil/gas
3. air cooled or water cooled? I didn't see a pee hole.
4. Neutral? sure was fun testing the motor in a trash can with the prop spinning!!! I'm assuming there's no reverse.
I know you guys need some info to tell me anything so here's what I've got:
Made by clinton motors
model# K7002107A
serial# 647637
type# 6027370R
I'll search the forum for some of this stuff but there's a lot to filter through. Thanks guys......Tom
1. year
model# K7002107A
serial# 647637
type# 6027370R
