I have a 1985 OMC (GM I believe) 4cyl 3.0l engine with an OMC stringer outdrive. The model number on the outdrive is 983486 and the sn is 1401147.
This is kind of a two part question. First, I am trying to install a water pump kit in the outdrive upper gearbox. I have replaced the impeller before and it was cake, this time I am trying to remove the impeller housing and it won't budge. I have looked at many diagrams and pictures trying to figure out if it is attached by anything else other than the 4 bolts that hold the whole pump together and I can't seem to find anything. Is there anything else that holds the impeller housing in that I am missing, and if so, how would I remove it? My other thought is that it could have possibly corroded or rusted in there and is just stuck, any recommendations on how to remove it if that is the case?
Second, the reason I am replacing the impeller, housing, etc. is because at plain the boat is overheating but at idle it is not. The exhaust manifold and gooseneck are either new or very clean, and I have blown air and water through all of the hoses so I do not believe they are clogged, but I am going to try again. After doing some research and talking to a mechanic, I have come to the conclusion that exhaust might be leaking into the water pump or the pump might not have enough pressure because of a leak. If that is the case, what seals would need to be changed. This thread also basically explains the exact same problem I am having, but with a different engine.
http://forums.iboats.com/showthread.php?t=420685&highlight=omc+impeller+housing
Thanks for your help, it is greatly appreciated because I am going a little crazy.
