Re: edelbrock 1405 vac ports
Does your GM 350 have a pcv valve or only a dual vents? Most, especially Mercs, were only vents. Hooking one to the vacuum port on the carb, will be like a big vacuum leak, and make that car carb, which is jetted lean compared to a boat cal, even leaner.
