ebassett74
- Jul 19, 2010
- 14
I have a 1992 or so 115 and 150 yamaha motors. One starts to cut out and gain rpm when you are over 3700 rpm. I have removed and cleaned the carbs, checked and replaced spark plug wires but to no avail. The other seems to have a similar problem but it is fine until the motor runs for about 15 minutes. This motor cuts out on the higher end also. This even has the mechanic troubled. Does anyone have any idea why my two engines are doing this? I will answer any questions in detail if someone has a similar problem or a mechanic that has addressed this issue before. Thank you much.
