Hi all, I have (per the ID tag on transom mount) a 1973 1500. However, I suspect the block has been changed out because the two ground wires at the cylinder head that bolt to the lower pan have a smaller loop than the factory bolts. The loops were just "pinched" in under the bolt heads to hold them in. So...I suspect a different block was put in at some point. The serial number on the block itself is S762437, but I can not find anything on block serial numbers on the net. Anyone know how to figure out what this thing is?
Also, top cylinder compression is 130 psi while the rest are about 150. Looks like the top cylinder got hot on last run and actually started to blow off aluminum "Dust" on to bottom of sparkplug, top of piston etc... Is this a case of needing a rebuild or can I check/replace reeds, rebuild carb and fuel pumps (remove problem of lean condition) and run it as is?
Thanks to all who contribute to this great site!
Tim
Tim
